We have stumbled or created a situation where the Measure Tool doubles the value of the actual dimension in plan. elevation or section. 2009
Any thoughts?
Any thoughts?
sounds like a Units setting?
please provide a bit more info........
OK, more info
It does not happen all of the time. It's hard to describe. We have a dimensioned floor plan set to 1/8", our units are Revit defaults, but when we use the measure tool to run a quick dimension, it shows as double the value of the related actual dim. this happens of exterior elevations as well. We use the measure tool to check the height of a window and instead of 4 ft by dim.,it measures 8 ft. high. It's seems like a bug to me.
Are you measuring from a Sheet View? and maybe the Viewport is not active?
