Thread: Ceiling Mounted Monitor (need a little guidance/help)
    2002-06
    North Central CT
    1,108
    Default Ceiling Mounted Monitor (need a little guidance/help)
    I need a little help here. I've got a ceiling-mounted monitor that I've been working on and I'm trying to make the mounting distance from the ceiling parametric. I've got the pole part working, but I can't figure out how to make the monitor move with the pole when the distance parameter is changed. Can someone take a look and point me in the right direction?
    Thanks in advance!
    Matt
    (the attached family is 2009)
    2002-06
    North Central CT
    1,108
    Default Re: Ceiling Mounted Monitor (need a little guidance/help)
    Well, I managed to hack something together... not sure if it's the best/most elegant way, but it's working. I've got the monitor as a nested family.
    If there's a better way to do this, please let me know.
    Thanks.
    Matt
    2006-09
    The Kingdom of Denmark
    560
    I´d do it just the same way ! I always build my families as non hosted, and then - when needed - throw it into a hosted family, just as you did.
    Doing so, makes it a lot easier to re-use the same content, in a lot of ways. Well done
  1. Ceiling-mounted projector
    By adegnan in forum Revit Architecture - Families
    Last Post: 2020-07-28, 05:05 PM
  2. Ceiling mounted receptacles
    By Ravintron in forum Revit MEP - General
    Last Post: 2012-03-20, 10:55 AM
  3. Ceiling Mounted Outlet
    By harkeychad in forum Revit Architecture - General
    Last Post: 2010-10-27, 05:51 PM
  4. ceiling mounted downlight
    By Tobie in forum Revit Architecture - Families
    Last Post: 2005-07-21, 06:39 AM
  5. Ceiling mounted lights dont mirror or copy well
    By sbrown in forum Revit Architecture - General
    Last Post: 2005-01-03, 09:41 PM
