Results 1 to 10 of 10
Thread: Graphics issue - Windows 7 x64
    2004-06
    Memphis TN area
    7,048
    Default Graphics issue - Windows 7 x64
    Not sure if this is a Windows 7 thing or common with any x64 OS and Revit 2010 x64 or what. Sometimes my ribbon will blink out and then come back. The project browser appears to extend up when this happens. Nothing changes or shifts in the drawing area, and the ribbon will come back when I move the mouse up into that area of the screen. Anyone seen this before?
    2006-01
    4,516
    Default Re: Graphics issue - Windows 7 x64
    I read on Revit Clinic that some people running Win7 through a Mac and Paralells was having trouble with the ribbon... Making sure Hardware acceleration was cranked up (either in hardware of vid card settings... i didnt read too closely as im not a mac user, or a win7 user, lol) seemed to help...
    AUGI Addict DaveP's Avatar
    2002-12
    St Paul, MN
    1,569
    I've seen it happen.
    Straight Win7 Pro, Revit 2010 SAP1
    Same symptom as you, Pat. The Ribbon just turns black, and then re-appears when you move the mouse over it.
    That and the Workshare Monitor not working are the only Win7 issues I've had.
    All AUGI, all the time gwnelson's Avatar
    2003-04
    Westchester County, NY, USA
    612
    Yeah, similar graphics issues here, too. Accel disabled, tried several drivers, etc, etc. Annoying, but able to get work done in spite of probs.
    2015-11
    standing @ the crossroads
    241
    Interesting! When I was running Vista x64 I would see this at least once a day. Now I have been running Windows 7 x64 for about 2 weeks and have yet to see it.
    2004-06
    Memphis TN area
    7,048
    Just installed the latest nVIDIA Quadro driver, and still have the same issue. HW Accel on or off, doesn't matter.
    While I haven't had any actual problems, it's just giving me the feeling that it's "unstable" and could come crashing down at any moment, despite having 16 GB of memory, new HDD, etc.
    2001-12
    1,714
    Quote Originally Posted by patricks View Post
    I wonder, do you still have the problem with Aero turned off, or at least transparency turned off, in Windows 7? I find all the bling to be needless "look at us, Just Like Apple" nonsense. And given the load things like transparency put on the graphics card, it could have an impact.
    Gordon
    2008-01
    Perth WA
    294
    I have been having the same issue with Vista & 32 bit RAC 2010 SP2.
    Luckily it is only on my home machine so no real issues.
    2004-06
    Memphis TN area
    7,048
    Quote Originally Posted by gordonp.230665 View Post
    Gordon
    I turned off transparency and will see how it goes.
    I really don't like Aero turned off. For one thing, it makes my left side (primary monitor) contents bleed over about 10 pixels into my right screen. It's super annoying and just generally looks bad. I'm not sure if this is a documented issue or not.
    2004-06
    Memphis TN area
    7,048
    Well, changing to a different, non-Aero theme seems to do the trick. I just have to manually pull the edges of the Revit window to the edges of the display to keep it from bleeding over to the other display.
    I have to say, though, that I don't like the looks of everything as well as with Aero turned on.
    FYI turning transparency on/off didn't make any difference.
  1. Graphics windows outside the program window
    Last Post: 2018-10-18, 12:28 PM
  2. Graphics cards for Windows 7
    By jimmy.long in forum Hardware
    Last Post: 2012-03-06, 06:21 PM
  3. Graphics Issue or Revit bug?
    By dgt.mantis in forum Revit Architecture - General
    Last Post: 2011-05-11, 10:49 PM
  4. UI Graphics Issue
    By jlinger in forum Revit Architecture - General
    Last Post: 2010-03-31, 07:44 PM
  5. Graphics issue in SD mode
    By bill0246 in forum Revit - Platform
    Last Post: 2008-11-24, 03:37 AM
