Thread: Document large radii using foreshortened radius dimensions as outlined in ASME Y14.5
    Wish List Administration
    2006-03
    1,102
    Default Document large radii using foreshortened radius dimensions as outlined in ASME Y14.5
    Summary: I would like to be able to efficiently document large radii using foreshortened radius dimensions as outlined in ASME Y14.5
    Description: I would like to be able to efficiently document large radii using foreshortened radius dimensions as outlined in ASME Y14.5
    How Used: There is currently no way to correctly show large radii on a drawing such that the distant center of the radius can be moved closer to the view and properly dimensioned. Ref. ASME Y14.5M-1994 sec. 1.8.2.2. Current workaround is to place a very small feature at the most distant radius center and use a broken view, but this still does not display radial dimensions correctly.
    Feature Affinity: Drawing Manager
    Submitted By: Samuel Bixler on November 5, 2009
    2011-08
    4,581
    Exclamation Re: Document large radii using foreshortened radius dimensions as outlined in ASME Y14.5
    Product and Feature: Inventor - Drawing Manager
    Submitted By: Samuel Bixler on 11/05/2009
  1. Foreshortened Radii with Center Mark
    Last Post: 2015-10-14, 03:05 PM
  2. Foreshortened Radii Displayed IAW ASME-Y14.5
    Last Post: 2015-10-12, 04:18 PM
  3. dimensions on two radii
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2013-10-25, 12:52 PM
  4. 2010: Placing dimensions on non-orthogonal radius?
    By kath.c in forum Revit MEP - Families
    Last Post: 2011-09-02, 03:14 PM
  5. Radius dimensions in 2008
    By ralph.burkey in forum AutoCAD General
    Last Post: 2009-08-17, 03:57 PM
