Results 1 to 1 of 1
Thread: format / multi-line of text label
    All AUGI, all the time Ning Zhou's Avatar
    2006-08
    636
    Default format / multi-line of text label
    not sure this is still an issue, if so, then what's the best workaround up to date? thanks.
    edit: Ctrl+Enter to add a line break or Ctrl+V to directly paste from formatted text (notepad, wordpad, etc.) are the existing workarounds
  1. Is there a way to format a field for multi-line?
    By dfarris75 in forum AutoCAD Fields
    Last Post: 2017-11-27, 09:33 AM
  2. Replies: 3
    Last Post: 2012-12-19, 03:00 PM
  3. Line spacing In Multi Line Text
    By STHRevit in forum Revit Architecture - General
    Last Post: 2008-09-22, 09:59 AM
  4. Convert single line text to multi line text?
    By civilguy in forum AutoCAD General
    Last Post: 2006-10-11, 11:37 PM
  5. Using fields how to set up with multi. line text
    By pangell in forum AutoCAD Fields
    Last Post: 2005-06-09, 05:19 AM
