Thread: project slow-down after enabling worksets
    2006-05
    6
    Default project slow-down after enabling worksets
    I am working on a fairly complex residential project where nearly all the custom built-ins, stone fireplaces, beams, brackets etc. are modeled. It was working well until I enabled worksets, and the lag time on my commands and regeneration time have gotten incredibly slow. Can anyone help me with this?
    Certifiable AUGI Addict
    2004-05
    St. Louis, Missouri
    3,135
    Cool Re: project slow-down after enabling worksets
    Check your network ( LANl and/or WAN ) connection speed, and the hub/switch.
    Sounds like now that the large Revit file is being shared over the network, the pipe
    speed is causing a performance hit?
    Enable the Worksharing Monitor, and check performance.
    How big is the file? (200 MB or larger may need to be broken into linked models)
    cheers...............
    2009-04
    28
    Default Re: project slow-down after enabling worksets
    Also, are you still working in that one central file or are you (as I hope you are!) working in a local copy?
    Working in local should make things quicker.
    2006-05
    6
    Hi Cliff,
    Thanks for your input. You mentioned enabling the worksharing monitor to check performance. How does one do this?
    THanks,
    Nora
  1. Enabling worksharing on 2010 is slow
    By matt__w in forum Revit Structure - General
    Last Post: 2010-09-30, 03:26 PM
  2. Slow down of worksets in 8
    By kentw.93991 in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2005-09-07, 11:23 PM
  3. Error Enabling Worksets
    By iru69 in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2005-06-18, 12:01 AM
  4. Worksets on a new project
    By jwilhelm in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2005-06-12, 03:24 PM
  5. Worksets on a new project
    By jwilhelm in forum Revit Architecture - General
    Last Post: 2005-06-12, 04:47 AM
