Hi, bigtime newcomer to this.
Summary: An Autolisp function or command button to select all, change colours and to move certain items so much in X & Y.
Description: I could do with making a macro of some description to basically select all on a drawing, change all the colour to white, then I need to select a certain area change to red (as it’s a security stamp and can only be in red) then I need to select another area on the drawing which is always going to be the same and to move what’s there 2mm to the left and 1mm upwards.
How Used: I’ve basically got loads of drawings I need to change everything to white so when I create a DWF file our client can read and the stamp will always be in red.
