Also - back on topic we are doing x3 Shadow Diagrams for 22nd June and x3 for 22nd December, results are all loaded on the same sheet.
SO......I cant print one sheet out without either the December or the June ones being wrong.......(I have to export/import images with daylight saving button clicked or unclicked)
Hi Alex,
I am not having the same problem as you.
In my instance, it is only the shadows where I had selected the daylight savings box which were changed. Other shadows (where the box is blank) still display correctly.
Thus I can put both daylight savings views and standard views on the one sheet.
Yours is a much bigger problem than I was having.
Cheers,
Ian
Maybe Im doing something wrong then...isnt the daylight savings 'click' boc under "Manage Place and Locations" - On my Revit it acts as , say 'Type' based, not 'instance' based (ie: Its a project wide setting)...
Hi Alex,
I access the daylight savings tick box through the Graphic Display Options at the bottom lhs of the screen.
Typically, I would set up a number of views with different shadow times. When you click through the the buttons to set the right location etc I do end up at the manage place and locations, but the daylight saving button here only activates the one hour change for the current view and has no impact on any other view.
Maybe it is type based when access from the ribbon and instanced based when access from the view itself??
Hope it helps
Ian
My apologies, you are totally correct!
This is surely a complete balls up and makes the whole purpose of the daylight saving button untenable. If we can't have shadows which are simultaneously correct for both standard time and daylight saving time, we cannot in any circumstance use this function.
AutoDesk - are you aware of this?
I now shudder at the thought of how many applications I have made which have been wrong - thankfully the council officers have, to date, not picked it up and as yet, I have not been grilled at the tribunal over any errors in shadows.
This button should immediately be either removed from the program or made to work on an instance basis.
Again Alex, sorry for the earlier inaccurate comment.
Ian
However, If I have this right, the work around would be to run with the daylight saving off, and purely set the view up for a one hour difference on the views that lie in a daylight savings period. I.E. for a midday scene in summer, plug in 11am. At least the view title doesn't carry parametrically your input into the time box.
Would this approach work?
peter
Yep,
You are absolutely correct. This is indeed what I have been doing since becoming aware of the significant shortfall in functionality of the daylight saving function in Revit.
Pretty simple really.
Unfortunately, as it is, the whole daylight saving function in Revit is useless and in my view downright dangerous from a litigation point of view.
As at the time it wasn't a support request, I emailed Anthony Hauck at Autodesk directly expressing my concerns and suggesting he, or someone within Autodesk, follow this thread. I have had no indication if Autodesk are aware of the issue or not.
Thus from now on, I will manually adjust for daylight saving & forget that any such function ever existed in Revit.
Cheers,
Ian
