Thread: Fillet multiple pline objects?
    2002-09
    Greeley, CO
    44
    Default Fillet multiple pline objects?
    I am working on a lisp routine and I just hit a wall. I have multiple rectangles or plines I need to fillet all at the same time (in a single user selection). Changing color and layer was no problem but for some reason I can't get it to fillet more than one object. Anyone know a work around?
    PS Add MENOTE to your layers or the routine will fail.
    (defun c:aeoutline()
      (setq oldf (getvar "filletrad"))
    	(setvar "filletrad" 12)
    (setq OBJ(ssget (entsel "\nPick pline or rectangle to convert to detail border:")))
    (command "FILLET" "P" OBJ "" "CHANGE" OBJ "" "P" "COLOR" "MAGENTA" "LA" "MENOTE" "LT" "HIDDEN" "")
      (setq OBJ nil)
    	 (setvar "filletrad" oldf)
    Earth
    9,804
    Default Re: Fillet multiple pline objects?
    Try looping through your selection set of polylines, and using the Polyline option of the Fillet command. Here is a sample.
    (if (setq i 0 ss (ssget '((0 . "POLYLINE,LWPOLYLINE")(-4 . "&")(70 . 1))))
           ;; ssget code above only selects closed polylines
      (progn
        (while (< i (sslength ss))
          (setq x (ssname ss i))
          (command "._fillet" "_P" x)
          (setq i (1+ i))
    R.K. McSwain | CAD Panacea |
    2002-09
    Greeley, CO
    44
    Thank you very much for the reply rkmcswain. It works perfect. Below is the working lisp we will use.
    (defun c:aeoutline ()
      (setvar "cmdecho" 0)
      (princ "Select Callout Border Lines")
      (setq
        i  0
        ss (ssget
      (progn
          (command "fillet" "P" x)
          (command "chprop"	x "" "color" "magenta" "ltype" "hidden"	"layer" "menote" "")
          (setq i (+ 1 i))
      (setq OBJ nil)
      (setvar "cmdecho" 1)
    2012-02
    14
    Quote Originally Posted by CAD Brad View Post
      (setq
        i  0
        ss (ssget
      (progn
          (setq i (+ 1 i))
      (setq OBJ nil)
    Hi CAD Brad,
    What I’m looking for is a lisp file that fillets all the CONNECTED selected lines/polylines (multiple)
    Is there such lisp?
    Thank you
    Best
    Jamal
    2015-10
    Belgrade, Serbia, Europe
    564
    Jamal, I've changed my mintfillet.lsp to include modify option of existing fillet...
    My version works with LINE and ARC entities, but above posted codes you may use for filleting POLYLINE entities...
    Hope this is what you're looking for...
    Regards, M.R.
  1. Fillet multiple select
    By dgleason in forum AutoCAD General
    Last Post: 2013-04-15, 08:59 PM
  2. PLINE with multiple linetypes
    Last Post: 2005-10-19, 10:56 PM
  3. Add multiple vertices to pline.
    By pgastelum77763 in forum AutoCAD General
    Last Post: 2005-02-26, 04:46 PM
  4. Multiple Pline Calculation
    By irar in forum AutoCAD General
    Last Post: 2004-11-04, 05:30 PM
  5. Fillet locked objects
    By Chad Smith in forum Revit Architecture - Wish List
    Last Post: 2004-05-31, 05:56 AM
