Hi,
i've a problem ...my corridor doesn't cut the terrain... i really don't know what i'm doing wrong!
I draw 3 lines: z=0 z=5 z=10
create a TIN surface adding with drawed entities
draw a poly and make it alignment
after it, i create a profile and draw a new layout on the profile
and finaly insert a simpy assembly
finally i create the corridor (assign Surface intersection "target surface" )
all works fine but! my terrein doesn't get a "hole" where my corridor is located
so I get corridors properties and in Surfaces, i change "create corridor surface" and add "daylight-fill" and "daylight-cut" after it in Boundaries tab I add an automatically "daylight".
It does nothing... won't cut! why?????
