Results 1 to 10 of 15
Thread: Linked file.... could not be located
    Active Member andrewharle's Avatar
    2016-01
    Harrow, UK
    50
    Default Linked file.... could not be located
    Having just moved my project into Revit 2010 I have now twice had this error...
    Linked file ..\..\..\filename.dwg could not be located. It will be displayed as it was when this project was last saved.
    Only it does not display the file. And what's more Revit will not let you locate it and reload it. The only way out is to unload the file and reload it.
    This has happened when the DWG has been edited, and then the Revit file re-opened or the link re-loaded.
    Any one had similar problems or knows what is going on?
    Andy Harle
    Revit 2016 windows 7
    Active Member ddragoo144336's Avatar
    2007-08
    Carlsbad, CA
    54
    Default Re: Linked file.... could not be located
    Quote Originally Posted by andrewharle View Post
    I am having the exact same problem but the one difference is that it cannot seem to be fixed - unloading the file and reloading does not change anything. On top of that, if I try to reload any of my other linked files (except for one), I get the same error message. These are files that I haven't even touched in any way.
    If I try to link another cad file into the revit file, it says that none of the elements are visible and there seems to be nothing that I can do to make it visible. It's almost like the file is linked (it shows up in the visibility graphics), but nothing is there.
    Of course I am working on a deadline from hell and am out of ways to fiddle with the files in hopes of it magically fixing itself.
    Any thoughts?
    2016-01
    Harrow, UK
    50
    Hi,
    The only thought I have is that in Revit 2009 we would find a drawing would jump to somewhere else if reloading a linked file that was too far from the orgin.
    We have given up loading most consultants files directly into Revit. Instead we make a copy and then drag the contents to match the shared coordinate we are using.
    Andy Harle
    Hi,
    I have a similar problem since 2 weeks. In the 6th week I've been working on a project with 2D DWG underlayers they suddenly start to give the error "linked file could not be located" When I do "reload from" they again give the error despite they are really there. The only "sollution" I found was removing them and relinking them into the model. The most remarkable fact is also that last week it were 3 files with this problem, this week 4 other files and 2 files haven't given these problems (yet).
    Since it's been a while since the last post, I hope you found a working sollution to this annoying bug.
    Greets,
    Matthijs
    environment: Win7 64bit / Revit 2011
    2016-01
    Harrow, UK
    50
    Hi,
    Sorry we have not found a solution to this problem. If you are a subscription customer I would suggest that you raise a Support Case on Autodesk Technical Support
    Its about time they sorted it out!
    We have not had the problem happen for a while - 2 months or so. We have never exactly worked out why it occurs.
    However we have still had problems with linked DWGs and I have spent a bit of time trying to work out what works and what doesn't - see post
    The conclusion I came to is that you should load all links into a specific view set to Project North, and never change this view to True North, otherwise strange things can happen!
    Andy Harle
    2011-04
    24
    Same problem after upgrading to Revit Arch 2012.
    It is quite frustrating to reload from, then click the file, then it says it cannot find the file...I just told it where the file is!
    2016-01
    Harrow, UK
    50
    Oh NO!
    Clearly the bug is still in Revit 2012 Update 2. I have no idea what causes it but I have just had a repeat of it - first time in ages. Had to edit an egineer's drawing (a practice we try to avoid - but need a correct Revit drawing for tenant) and now it won't load.
    Once this link has come up with this error no matter what file you try linking in, it just will not work.
    Andy Harle
    I could stop if I wanted to Revitaoist's Avatar
    2009-11
    380
    I convert all DWG's to Revit lines and copyclip to a new family so no CAD info gets into Revit. This happened to me when I linked a file into a site plan, then deleted the site plan after creating a new one. This is the fix:
    1. Manage > Location > Site > Duplicate current site location.
    2. Make new location current.
    3. Manage Links > Remove CAD Link.
    4. Manage > Location > Site > Make previous location current, delete temporary site location.
    Revit MEP Certified Professional
    In my experience this mainly/only occurs after upgrading a project to a new version i.e. from revit 2011 to revit 2012..
    Maybe this experience can help Autodesk find/fix the issue... it's happing since revit 2009.
    2015-12
    Chesterfield, MI
    405
    We've had this issue intermittently over the past few releases. I currently have an open Support Case with Autodesk on this problem with Revit 2012 (all flavors).
    The Revit file in question has a handful of AutoCAD links and only one of the DWG files is having this problem.
    For what it's worth, the last two responses from support have stated:
    "Unfortunately the workaround will be to unload and reload the files."
    "The development team is aware of this issue and they are working on it."
    To repeat part of an earlier response in this thread by "andrewharle"- "If you are a subscription customer I would suggest that you raise a Support Case on Autodesk Technical Support". The more reports they get of this issue, the better chance of it being assigned a higher priority.
  1. 2014: Linked file - By Linked View - Underlay function seems to be rendered invalid
    By NielsenDaniel in forum Revit Architecture - General
    Last Post: 2013-10-21, 07:44 PM
  2. PC3 file located on our server
    By jschraud228486 in forum AutoCAD General
    Last Post: 2011-01-18, 09:28 PM
  3. Replies: 0
    Last Post: 2007-12-20, 01:54 PM
  4. Everyone to work from the same Acad.pgp file located on the network
    By tim.101799 in forum AutoCAD Customization
    Last Post: 2006-07-19, 02:10 PM
  5. Where is the ACLT.pgp file actually located?
    By lloyd.101803 in forum AutoCAD LT - General
    Last Post: 2005-12-20, 03:50 PM
