I don't think this is possible but I told a user I would find out for sure.
We want to change the duct tag to read 12x24 and not 12"x24", is this possible?
You have to do this.
Edit the duct tag family.
Replace the size label with width and height from the catagory parameters (Do not use a shared parameter)
Format both width and height to decimal inches and change the unit symbol to NONE.
Saveas.
The same steps work by going into Units settings in the project and not editing the tag.
jason
Update.
Changing the Duct tag from size to width x height disables the ability to tag round duct.
Bad idea, unless someone knows another parameter I could use other than size.
Also changing the units in the project has no effect on the loaded tags.
Use the OOTB duct tag. In your project, Go to Project Units -> HVAC -> Duct Size -> change "Units" to Decimal Inches, "Rounding" to 0 decimal places, "Unit Symbol" to none
You can still tag round ducts with this method and the inch mark won't show up.
reheheheealy.
Nice.
Well sort of.
I am not using decimal inches but that'll do.
What if I want to achieve the same thing, but for my pipe tags?
