Hi,
I have created a supply fan family, with an LPHW heater battery. From various parameters, i can calculate the LPHW Flow required to heat the air, in kg/s. Now here is the tricky part...
Is it possible to use a lookup table to determine the LPHW connection radius if it knows the LPHW flow?
I have attached a lookup table with the correct values (not in .CSV because that is not a valid file upload type)
eg. (Flow between 0.159kg/s and 0.298kg/s requires a 32mm pipe, and therefore connection radius should be 16mm)
Thanks in advance for your help, i need it!
