Thread: Edit Room Boundary
    100 Club cdsuggs's Avatar
    2008-04
    LA area
    146
    Default Edit Room Boundary
    RAC 2010
    I have some rooms whose boundary's I wish to edit. I thought it was possible to edit the boundary in sketch mode however there is no Edit Boundary button.
    Any suggestions would be most apprecitive.
    Thanks!
    _________
    suggs
    2009-02
    10
    Default Re: Edit Room Boundary
    Are you trying to increase the boundary beyond the confines of the walls or trying to reduce the room to a smaller area than the walls. If you are trying to increase the room simply sketch the room boundary line beyond the wall(s) to where you desire. Then go to the properties of the wall and uncheck the box that says room bounding. If you are trying to simply decrease the size draw the new room boundary line inside the wall. If I am off base of what you are trying to accomplish post a screen shot of what you have currently and redline in what you actually want.
    Good Luck!
    2008-04
    LA area
    146
    Thank you for your reply, David!
    I am trying to reduce the room size however I cannot seem to edit the boundary of the room object. I can select it but cannot edit the object to adjust the sketch.
    I have tried to delete the room object and create a new room, however the boundary of the deleted object is still there and my new room object (once placed) is exactly like what was deleted.
    I hope I'm making sense.
    Not sure what the heck I'm missing.
    _________
    suggs
    AUGI Addict jeffh's Avatar
    2002-09
    Manchester, NH
    1,087
    The edges of a room object are defined by the surrounding "boundry objects" (typically walls). You can also create room seperation lines to establish the boundry of a room object.
    Both of these elements (walls and room seperation lines) are edited seperatly from the room object. The room simply conforms to the edited position of these elements.
    ______________________________________________
    Jeff Hanson
    Sr. Subject Matter Expert
    Autodesk, Revit User Experience
  1. Can not Edit Room Style Column in Room Schedule
    By sifuentes in forum Revit Architecture - General
    Last Post: 2014-11-19, 03:07 PM
  2. Need to be able to edit the shape of the room boundary
    Last Post: 2014-11-13, 07:04 PM
  3. Demolish by sketch (similar to "edit boundary/edit profile)
    Last Post: 2014-02-14, 05:18 AM
  4. floor boundary by room boundary
    Last Post: 2012-12-13, 03:34 PM
  5. Edit Text Mask Boundary
    By Spanky in forum AutoCAD General
    Last Post: 2007-12-05, 05:12 PM
