Thread: Imperial Units to Metric Units
    2016-01
    Honolulu HI
    9
    Question Imperial Units to Metric Units
    Can Revit convert easily to metric units and dimensions from imperial units?
    Also, can a Revit model be converted to Bently BIM model?
    The government projects we are working now are requiring the final models to be in Bently BIM. Who wants to learn that stuff after trying to learn Revit the last few years?
    Thanks
    All AUGI, all the time Henry D's Avatar
    2003-05
    Fairfield, Iowa
    669
    Default Re: Imperial Units to Metric Units
    I do work that involves switching back and forth between Metric and Imperial. Just go into the Project Units dialogue box and select Meters and Centimeters. If the Units Format in your dimension type is set to "use Project Settings" all the dimensions will automatically change.
    The other way to do this without changing the Project Units, is to have a Metric dimension type with the "use project settings" box unchecked, and then switch the feet and inches dimension type with the Metric dimension type.
    2016-01
    Honolulu HI
    9
    Smile Re: Imperial Units to Metric Units
    Mahalo!
    Thats what i was looking for.
  1. Switching units (metric to imperial) in families
    By argman in forum Revit Architecture - Families
    Last Post: 2024-01-30, 02:34 PM
  2. Change Units From imperial to metric
    By GrD in forum AutoCAD Structural Detailing
    Last Post: 2013-10-12, 02:14 PM
  3. HELP - Changing Revit units from imperial to metric
    By m.fabb425767 in forum Revit Architecture - General
    Last Post: 2012-01-21, 04:30 PM
  4. Converting a Survey from Metric to Imperial Units
    By marble in forum AutoCAD Civil 3D - Survey
    Last Post: 2011-11-22, 02:11 PM
  5. Scale List Units Metric / Imperial
    By H-Angus in forum ACA General
    Last Post: 2008-01-23, 09:27 AM
