Results 1 to 6 of 6
Thread: Constrain the parameter value & display an custom error message
    2008-08
    10
    Default Constrain the parameter value & display an custom error message
    Is there a way to pop out an error message describing the error when some undesired value is fed into the parameter in the project.
    "if (length<10000, Enter length greater than 10000, Length)"
    "Enter length greater than 10000" needs to pop out.
    Regards,
    Raghavendra Bhat
    All AUGI, all the time Munkholm's Avatar
    2006-09
    The Kingdom of Denmark
    560
    Default Re: Constrain the parameter value & display an custom error message
    Raghavendra
    Instead of repeating it here, just check out this Blog post
    - Klaus Munkholm
    2008-08
    10
    Thanks Mate I think this will work
    Only problem is if the family is of Metric Generic Model or of Metric Mass the text entered dose not have the visibile parameter.
    In this case what to do!
    Regards,
    Raghavendra Bhat
    Pittsburgh, PA USA
    1,906
    The other method is to Create a Nested Generic annotation family consisting of a Label. This nested annotation will always be readable, scalable, etc. Its value parameter can be "attached" to a text parameter in your family. I have a super long if statment in a family, that if any of a series of values goes out of range, then a text value, relating to that out of range is set for that value. This text could be the offending parameter name. To make My life easier, I actually have a Yes/No parameter for each parameter I am checking, and then the nested if, is only checking to see if one of these trigger Yes/No parameters is "True", and echos the text.
    2008-08
    10
    Thanks scott
    the first thing tomorrow i would do is try this out.
    Regards,
    Raghavendra Bhat
    2008-08
    10
    Thanks Scott!
    It worked for me! Thanks for your help.
    Regards,
    Raghavendra Bhat
  1. 2015: Display Custom Bend Deductions from Table as Parameter
    By d.m.polsky in forum Inventor - General
    Last Post: 2014-12-04, 02:19 PM
  2. Replies: 8
    Last Post: 2009-10-27, 12:03 PM
  3. Custom linetype error message
    By David van Erk in forum AutoCAD Customization
    Last Post: 2007-09-05, 04:50 PM
  4. Error Message: Display Error
    By mccurdyks in forum Revit - Hardware & Operating Systems
    Last Post: 2006-07-19, 07:21 PM
  5. Display Error Message
    By kjgiant in forum Revit Architecture - General
    Last Post: 2004-11-03, 09:51 PM
