Has anyone been using the Revit extensions to export a Model to KMZ file for import in to google earth? When we open the KMZ on 64 bit machines in google earth, the model looks destroyed. Faces arent straight, plenty of things are missing, and lines are just generally out of whack.
If i open the KMZ on a 32 bit system on WinXP, it looks great in Google Earth, but were hitting memory limitations on the model we want to import. Certainly plenty of you are doing this on Vista.... Yes?
I suppose its not really a Revit question, per se... The Globe connector works, but for some reason the KMZ it outputs is finicky about how it will react in GE....
