Thread: problems with generating rooms
    2008-09
    31
    Default problems with generating rooms
    Hi,
    I have a problem when generating rooms - walls that are above or beyond my current elevation seem to be taken into consideration - so instead of room defined by walls from current elevation I get a room which boundries are defined by mix of all walls (those from above, below, etc.)
    What do I miss?
    Thanks in advance,
    St.
    2008-09
    31
    Default Re: problems with generating rooms
    Hi,
    If my description is not clear enough (or at all), let me know - I'll try to describe it better.
    Maybe I try to change my question:
    How do you use generate room comand when you have few stories in the building? How do you choose which walls are used for boundry generation? Printscreen in attachment - as I am not sure if I translate the command properly.
    St.
    2015-10
    Sidney, Ohio
    24
    My first thought is that you should have a separate constructs for each floor. Then you would be dealing with only walls at your're desired elevation.
  1. Add Rooms Area when using From/To Rooms in Schedules
    Last Post: 2013-03-08, 07:49 AM
  2. Problems with rooms
    By djsli in forum Revit Architecture - General
    Last Post: 2010-10-27, 06:15 AM
  3. generating boundary
    By mdsalman2003 in forum AutoLISP
    Last Post: 2009-12-03, 01:28 PM
  4. Generating spaces using SQ.FT.
    By kevin.198825 in forum ACA General
    Last Post: 2009-01-19, 12:35 PM
  5. Rooms Overlapping at Level - Furniture Schedule Problems
    By lhanyok in forum Revit Architecture - General
    Last Post: 2007-11-16, 02:20 PM
