Thread: Importing Fonts
    2009-11
    3
    Unhappy Importing Fonts
    I have looked at the help section within Revit and on this website and I am still lost. I am trying to import a font. I see it in the Data file within the Revit folder but I can't seem to open it or import it in or out of Revit. The directions of what to do with this file are sketchy.
    2000-01
    Seattle WA USA
    5,859
    Default Re: Importing Fonts
    Fonts in Revit are all TrueType-based fonts. So they need to be installed to the operating system's Fonts folder.
    R. Robert Bell
    Design Technology Manager
    Stantec
    2009-11
    3
    Quote Originally Posted by RobertB View Post
    WHAT DOES THAT MEAN?
    AUGI Addict DaveP's Avatar
    2002-12
    St Paul, MN
    1,569
    Revit doesn't have its own fonts like AutoCAD does. Revit just uses the Fonts that are installed for Windows. You typically install Windows fonts simply by dragging them into the C:\Windows\Fonts folder.
    However, I have a sneaking suspicion that this is not what you want, either.
    What's the file name of the font in your Data folder? Is it a TTF? If it is a .TTF or .OTF, you're OK.
    If, however, you have a .SHX file, you won't be able to use it in Revit. SHX is a file format specific to AutoCAD and Revit won't recognize it.
  1. Bad Fonts ( Arabic Fonts)
    By moshira_hassan in forum AutoCAD General
    Last Post: 2010-06-22, 08:28 AM
  2. 8.1 and New Fonts/Importing Fonts
    By briandiercks in forum Revit Architecture - General
    Last Post: 2007-03-05, 11:23 PM
  3. Different fonts have started showing up as default AutoCAD fonts
    By jackie.112886 in forum AutoCAD General
    Last Post: 2006-05-15, 11:02 PM
  4. DWF loses protected fonts - download fonts option?
    By christo4robin in forum Revit Architecture - General
    Last Post: 2006-03-25, 12:01 AM
  5. shx fonts to true type fonts
    By sbrown in forum Revit Architecture - Tips & Tricks
    Last Post: 2004-03-31, 02:53 PM
