Thread: INVENTOR UNITS
    2009-02
    Louisville, KY
    Default INVENTOR UNITS
    IS THERE A WAY TO CHANGE "UNIT OF MEASURE" IN INVENTOR 2010 FOR ALL PARTS OF AN ASSEMBLY?
    2008-02
    Central IL
    53
    Default Re: INVENTOR UNITS
    Here is a simple loop routine that will get you started:
    Public Sub ChangeUnits()
        'Set a reference to the current inventor document.
        Dim InvDoc As Document
        Set InvDoc = ThisApplication.ActiveDocument
        Dim Refdoc As Document
        'Initialize error trapping
        On Error GoTo ERROR_QUIT
       'Set all referenced files unit of measure to Inches
        Dim oUOM As UnitsOfMeasure
        Dim eLengthUnits As UnitsTypeEnum
        'Loop thru all documents referenced by the active document
        For Each Refdoc In InvDoc.AllReferencedDocuments
            Set oUOM = Refdoc.UnitsOfMeasure
            eLengthUnits = oUOM.LengthUnits
            'Debug.Print oUOM.GetStringFromType(eLengthUnits)
            'Check to see the length unit type
            If oUOM.GetStringFromType(eLengthUnits) <> "inch" Then
                oUOM.LengthUnits = kInchLengthUnits
                'Inform the user that a part had its unit of measure changed
                MsgBox "Part " & Refdoc.DisplayName & " UnitsOfMeasure changed to Inches"
            End If
        Next
    ERROR_QUIT:
        Exit Sub
    End Sub
  1. 2014: Revit Lookup Table Acceptable Units - Consolidated List? / Units for ##NUMBER?
    By DMagillIII in forum Revit MEP - Families
    Last Post: 2015-01-23, 08:55 PM
  2. Add Architectural Units to Inventor
    Last Post: 2012-08-18, 01:31 PM
  3. INVENTOR - VBA units
    By clovis in forum VBA/COM Interop
    Last Post: 2012-07-16, 02:05 PM
  4. Replies: 4
    Last Post: 2007-12-10, 07:03 PM
  5. Convert Civil drawings using decimal units into Arch. units
    By tlarocco in forum AutoCAD Civil 3D - General
    Last Post: 2006-07-17, 05:52 PM
