Results 1 to 10 of 10
Thread: Creating object to define window space
    2009-12
    5
    Unhappy Creating object to define window space
    Im creating window in old castle type building, (reconstruction).
    But to add around window inside with vault above window. I have created this object but nit having luck to add it into one piece.
    Is there any fater way for this or windows just have space only calibrated to their size?
    Attachement 1 is object i created
    Att 2 is scan from blueprint
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Default Re: Creating object to define window space
    You need to create a window family and delete the opening and replace it with a void or multiple voids that cut the shape you want to remove from the wall.
    Scott D. Brown, AIA
    BECK
    2004-06
    Memphis TN area
    7,048
    Also in the window family, change the host wall thickness to match (or closely match) the wall thicknesses you'll be working with, before you get started on the actual window family. The default 6" or 150mm or whatever wall thickness just won't cut it when you're trying to make something for a massive stone wall.
    2009-12
    5
    Quote Originally Posted by sbrown View Post
    Can you please describe it with commands/ panels ?
    I should copy some family and change it in editor or its just some advanced propertie of inserting window.
    How to create Void with window ? (command)
    Im new for revit so please examples or commands are appreciated ))
    New thing 1:
    I need to create a ceiling vaulted. But only ceilings i found are linear shape. Where i can edit them / add my own shape ?
    New thing 2:
    I also came to that some walls have not rectangular shape, i used command to edit them "Edit Cut Profile" but it seems to edit them only in Floor plan but not in 3D models ... ?
    2009-12
    5
    Hi,
    when i delete void in window family, I create new one but it didnt cut the wall in 3D and it has yellow color ... whats the mistake I did ?
    2006-06
    Toronto, ON
    2,386
    You need to select the option Cut Geometry, select the void and then select the wall. This will make the void cut the opening in the wall.
    Andre Carvalho
    2009-12
    5
    So now i got parametric opening but all windows I found makes they thicknes about 1000mm because wall is that strong, but i need inly in 1/2 (500 mm).
    How can I do this ?
    2006-06
    Toronto, ON
    2,386
    Quote Originally Posted by xzavoral View Post
    How can I do this ?
    Can you clarify your question, please?
    Andre Carvalho
    2009-12
    5
    I have window family. Deleted the opening and created Voids like I posted in 1st post (Picture).
    But when I insert window in Family Editor to create whole block (hole+window) in wall 1000mm thick, the window uses the 1000mm thickness of wall instead of 500 (look at picture in first post how the 2-glass window should be placed.
    So the window uses 1000mm thickness and I cant get it to use the 500mm (half of wall size).
    Sry for my bad English It's not my native language ...
    Hope you understanded me
    thx for help
    2006-06
    Toronto, ON
    2,386
    Most windows families will have a frame which is connected to reference planes called exterior and interior (for exterior and interior faces of the wall). It's like that to allow the frame to stretch and change its depth as the wall thickness change.
    All that said, what's probably happening to you is that your window family is looking for the wall thickness and if you don't want that behavior, then you have to edit your window family, and unlock the frame extrusion (or sweep) from that reference plane. Then you can add a parameter to manually control the frame depth if you want.
    Andre Carvalho
  1. Copy Object Properties Before Creating a Similar Object
    Last Post: 2012-07-01, 03:03 AM
  2. Linking Fields - Paper space to Model Space Object
    By red2002yzfr1 in forum ACA General
    Last Post: 2010-03-23, 12:02 PM
  3. How I can activate object osnap to define a view
    By allands36 in forum AutoCAD Tips & Tricks
    Last Post: 2008-07-07, 04:21 PM
  4. Is there a way to define ref plane by 3 points in space?
    By Gadget Man in forum Revit Architecture - General
    Last Post: 2005-02-03, 10:48 PM
  5. Window and Space Object Property Sets
    By arcadia_x27 in forum ACA General
    Last Post: 2004-07-03, 12:53 AM
