Results 1 to 8 of 8
Thread: Problem with View References and dependant views
    2009-12
    Golden Isles, Georgia
    13
    Question Problem with View References and dependant views
    I'm having a problem getting my view references to display correctly for my matchlines. I went through the advanced tutorial to try and trouble shoot this issue but I can't seem to figure it out. Here is what is going on.
    1. I created my dependant views from the parent view
    2. I placed the dependant views onto their respective sheets
    3. I drew matchlines on the parent view (in this case a floor plan) using the matchline tool.
    4. Using the view reference tool, I placed the tags making sure that the correct taget views are selected.
    Problem: the references just say "Ref". When I go to their properties, the correct information (sheet nember/ detail number) is contained within, but the tag itself will not display it.
    Has anyone else had this problem and if so, how did you fix it? I really like the idea of the dependant view/ matchline feature and would like to take advantage of it.
    Thanks!
    Pittsburgh, PA USA
    1,906
    Default Re: Problem with View References and dependant views
    What version of Revit are you using?
    2009-12
    13
    Revit 2009
    Pittsburgh, PA USA
    1,906
    When you place the reference, in the tool bar at the top, you need to pull and select the view that you want that arrow to reference.
    2009-12
    13
    I actually did that. That's why when you click the reference and go to its properties, it actually shows the correct information. However, in the drawing it only displays as "Ref".
    All AUGI, all the time mwiggins121466's Avatar
    2006-09
    576
    You have to edit the tag and add the proper labels in the tag.
    Margaret Wiggins
    Revit MEP 2006 and Greater
    Electrical Designer
    Detroit, Michigan
    wigginsm@yahoo.com
    2009-12
    13
    I'll try that, but isn't it supposed to display the correct information automatically? It did when going through the tutorial. The only other thing that I can think of is that someone in the office messed with the reference tag family and screwed it up (unless I'm just missing something, which happens from time to time).
    2005-02
    44
    If anyone else has this problem...
    Edit the Type Properties of the tag. Under View Reference Tag, it is probably set to "none". I didn't have any others to choose from, so I started a new blank file from the default Revit template and used Transfer Project Standards to bring it in. Somehow all View Reference items were purged from our office template.
  1. Include View References in Find Referring Views
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2017-03-20, 11:36 PM
  2. Allow Detail views to duplicate as dependant views.
    Last Post: 2012-11-26, 03:56 PM
  3. Ability to create view references in Legend views.
    Last Post: 2012-10-25, 03:36 PM
  4. dependant view crop boundary problem
    By gordolake in forum Revit Architecture - General
    Last Post: 2009-01-23, 04:55 AM
  5. Duplicate view and All Dependant Views.
    Last Post: 2008-07-21, 05:46 PM
