Thread: 3D Rendered Sections
    2009-12
    10
    Post 3D Rendered Sections
    Hey Everyone,
    I was just wondering if anyone could kindly tell me how I can create a 3D rendered section of a building?
    Lisa
    2008-01
    Perth WA
    294
    Default Re: 3D Rendered Sections
    I will provide and answer for you in 2010.
    There are a couple of ways to do this.
    First method requires at least one section in your project.
    Open a 3d view, Duplicate it and rename the new view to something that you like ie 3D Section AA (or something like that)
    Move your mouse over the view cube (should be top right of screen) and right click.
    You should see a menu that contains "orient to view"
    When hovering over "orient to view" a second fly out menu will appear with
    Floor Plans
    Elevations
    Sections
    3D Views
    Hover over the section category and a list of the sections you have in your project will appear. Select the section you wish to have as 3D
    This will create a 3D view which imitates the section you selected. You can then manipulate the view like any other 3D view and it can be rendered.
    Second method, If you don't have a section you want to replicate. Simple go to a 3D view>view properties and turn on your "section box" this can be manipulated the cut the building wherever you would like. It can then be rendered out.
    2009-12
    10
    Thank you so much that was great! They look really good when there rendered. Very surprised. Thanks again.
    Lisa
    AUGI Addict truevis's Avatar
    2004-07
    Massachusetts, USA
    1,191
    Also, 'Poche' is the material that shows when things are cut by the Section Box and you have Coarse detail level.
  1. AEC-sections or similar "single"-section + sections without depth
    Last Post: 2014-11-14, 06:56 AM
  2. First Rendered Project
    By harkeychad in forum Revit - Rendering
    Last Post: 2006-06-01, 12:01 PM
  3. Building sections vs wall sections-best practices
    By jwilhelm in forum Revit Architecture - General
    Last Post: 2005-10-12, 03:05 PM
  4. Building Sections vs Wall Sections
    By Alex Page in forum Revit Architecture - General
    Last Post: 2004-07-26, 08:49 PM
  5. RENDERED elevations
    By Steve Jager in forum Revit Architecture - General
    Last Post: 2003-10-23, 07:59 PM
