Thread: Regarding Constraints, I should probably know this by now, but....
    100 Club WolffG's Avatar
    2003-06
    Syracuse NY, USA
    157
    Default Regarding Constraints, I should probably know this by now, but....
    This is probably a real newbie question and I should know the answer, but it's frustrated me nonetheless.
    I seem to spend a great deal of time while developing a set of drawings on fixing, refixing and re-re-fixing the locations of objects which somehow slip out of alignment while I'm working on something else.
    I think I'm probably using constraints wrong, but I'm not sure how to use them properly. Maybe somebody can point me in the right direction. Since at least one set of drawings has gone out into the field with some messed up relationships, this has become more than an academic issue. Thanks for all help.
    BTW, what's the difference between the padlock constraing and the pushpin thingie?
    Revit Family Guy adegnan's Avatar
    2003-04
    DeForest, WI
    633
    Default Re: Regarding Constraints, I should probably know this by now, but....
    A padlock will constrain one object to another.
    A pin tack will "constrain" virtually all aspects of an object.
    If you want to constrain on object to another, such as a the alignment of two walls in plan or a foundation with a framed wall in section, use the padlock (the alignment command).
    If you want to constrain an object permanently, use the "pin" constraint. This could work for grid lines and reference planes, for instance. It can also be used on other objects too.
    Revit Founder irwin's Avatar
    2003-08
    Waltham, MA
    330
    Put another way:
    - If you want an object to stay where it is, use the push pin.
    - If you want an object to move whenever some other object moves, lock a dimension or alignment.
    2003-06
    Syracuse NY, USA
    157
    Thumbs up Re: Regarding Constraints, I should probably know this by now, but....
    Thanks.......now why couldn't they write it this clearly in the manual? Some of us old farts need to have things explained s l o w l y and simply.
  1. constraints
    By gugg in forum AutoCAD General
    Last Post: 2012-05-08, 05:31 PM
  2. FEA Constraints
    By mankie1926260 in forum Inventor - General
    Last Post: 2011-08-11, 04:16 PM
  3. Constraints: Sightline Based Constraints
    By ronjon in forum Revit Architecture - Wish List
    Last Post: 2005-01-11, 02:40 PM
