Thread: DWF publish question
    2007-12
    222
    Default DWF publish question
    Not sure if this is the correct forum...
    We are using Architecture 2009/ Project Navigator and one of our users accidentally published multiple files to a single dwf instead of multiple dwfs. Is there a way to separate these files as we would a pdf or does he have to redo the publish (which I think he already has)?
    Earth
    9,804
    Default Re: DWF publish question
    Re-publishing is certainly easier, but you can open two sessions of Design Review and drag+drop sheets from one to another. So you could open your single set and drag+drop sheets to a new empty file, and save them off one at a time....
    R.K. McSwain | CAD Panacea |
  1. Publish error Page Setup works Publish won't
    By jmagarolas962356 in forum AutoCAD Plotting
    Last Post: 2011-02-11, 12:29 AM
  2. Publish to 2D DWF
    By chammer in forum Revit - Plotting/Printing/Exporting
    Last Post: 2008-12-29, 05:58 PM
  3. only publish the first drawing in the publish list
    By bigpigdig in forum AutoCAD Plotting
    Last Post: 2006-08-04, 12:16 AM
  4. Replies: 3
    Last Post: 2006-02-13, 10:03 PM
  5. Publish
    By cparvez in forum AutoCAD Plotting
    Last Post: 2004-07-26, 06:28 PM
