Results 1 to 8 of 8
Thread: 3D DWF to 3D DWG
    100 Club andrewp's Avatar
    2003-06
    149
    Default 3D DWF to 3D DWG
    is it possible to save a 3D DWF to a 3D DWG?
    Drew
    2009-04
    Default Re: 3D DWF to 3D DWG
    I don't think there is a way to convert dwf to dwg, but if there is I would like to know about it. Unless there is another way, at one time the dwf was a dwg, and some one should have the dwg.
    Mark
    Williamsport, PA
    641
    A DWF is usually created as a method of protecting intellectual property rights. Probably the easiest method is to request a dwg from the owner of the intellectual property.
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    AU 2007 Avatech Altogether Smarter Inventor On-line Challenge 1st Place
    Autodesk Inventor Certified Expert
    Certified SolidWorks Professional
    Williamsport, PA
    9,771
    Exclamation Re: 3D DWF to 3D DWG
    Quote Originally Posted by mturner.213324 View Post
    Plain old 2D DWF files are fairly trivial to convert back to DWG, but of course a lot is lost in the original conversion to DWF, which you won't get back going to DWG.... but for 3D, it would depend on how the data is stored in the DWF file... which I'm not sure about...
    To andrewp, this may be of some interest.
    http://autodesk.blogs.com/between_th...olkit_7_w.html
    2003-06
    149
    Okay... Got a 3D CAD Drawing created from the STP file... now trying to load it into SketchUp... Stuck on 99%... Anything i can do in AutoCAD to make it a less complex drawing?
    Drew
    Williamsport, PA
    641
    Can you attach the STEP file here?
    Williamsport, PA
    2006-04
    (getpoint "Anywhere on the Enter Key =>")
    1,160
    There are some DWF to DWG converters & do the 3d drawing conversion. ie. Auto DWG
    You can do a google.
    PS. Does anyone know if there is a free DWF to STP convent or? Thanks.
    2015-09
    you can, sort of, use navisworks to convert a DWF to DWG. although this would be via an FBX file. i.e. append DWF to navis, export FBX, in AutoCAD import FXB.
