I have a AutoCAD LT drawing with symbols that aren't coming across in AutoCAD 2010. Is there a plugin for seeing these in AutoCAD 2010?
not that i've ever heard of. If LT can create it, full acad ought to work w/o problems.
What shows up in the text window when you run LIST in LT and pick the troublesome symbol?
can you post an example drawing with a symbol that doesn't show up?
See the list results. Apparentley, the originator used wingdings so the symbols are actually wingding text. I think I'll try a symbol replacement with something that makes sense. Thansk.
_list
Select objects: 1 found
Select objects:
MTEXT Layer: "Electric"
Space: Model space
Handle = 5764
Style = "Notes"
Annotative: Yes
Annotative scale: 1'-0" = 1'-0"
Width: 2'-10 1/2"
Normal: X= 0'-0" Y= 0'-0" Z= 0'-1"
Rotation: 0.00
Paper text height: 0'-8"
Model text height: 0'-8"
Line spacing: Multiple (1.000000x = 1'-1 1/2")
Attachment: TopLeft
Flow direction: ByStyle
Contents: {\fWingdings|b0|i0|c2|p2;a}
