Just be careful as it becomes easy to now tilt your view from Plan of the UCS. The middle button's also used for panning. There was quite a few questions on this forum which ended up being because the view was off Plan, this is probably the main culprit to that.
So if you want to pan, make sure your fingers aren't touching the Shift key. Some keyboards are just too sensitive.
Well after a few weeks of dialogue followed by a few weeks of silence. I received this from Autodesk today regarding this issue.
So it is now a confirmed bug in OSNAPZI wanted to check in with you and let you know that development is still researching this occurrence and it has been noticed through further testing that this problem has existed for a few releases and is on there radar for working this into a future release/service pack for the software. Thank you for your patience while we work to resolve and find resolution for you in this case. Any and all updates I receive I will expediently pass your way. please feel free at any time to ask/comment on this case. Thank you.
Best regards,
Michael Bussiere II
Autodesk Support Team
I've been using AutoCAD since R10, and have been using MText since it was introduced was back in R13. Even though I try to use as much as the Mtext formatting features as possible, there were/are still techniques I am only discovering now.
One of my new favourite things are using tab stops. Now, I've been using tab stops to indent separate lines of text for a long time now, but I only just discovered that the tab stops have different justifications.
I've been trying forever to find a way to right-justify thickness values of road materials while keeping the descriptions left justified. I only just discovered that while in the MText Editor, if you keep clicking the tab-stop icon box, it keeps changing the tab-stop styleto the desired justification.
Take a look at the attached graphic to see what I am rambling about
The FILTER command is a great one, you can even create multiple filters to narrow your search down, for some reason always happier to use than QSELECT.
Welcome to AUGI and congrats on your 1st post.
I agree, while the QSelect seems more user friendly - the Filter is more efficient (you can even save filters for use later in different DWGs). Unfortunately filter doesn't work well with some newer objects like dynamic blocks, for that QSelect's your only answer.
