Thread: Win 7 & Lose XP 64-bit - Your Input
    I could stop if I wanted to CEHill's Avatar
    2006-05
    TN
    327
    Question Win 7 & Lose XP 64-bit - Your Input
    Could someone assist in selling the idea of migrating the OS to Windows 7 from Win XP 64-bit. This will be a really difficult task from the local IT tech and myself to sell to the IT manager. We need any information / observations from reliable sources including yours.
    We suspect that the Autodesk software instability issues on my new Dell T7500 workstation are due in large part to limitations in the Windows XP 64-bit OS environment.
    We are focusing on the OS **ONLY** after several rounds of reloading CAD software and installing service packs/updates, accounting for any network issues, checking connections etc.
    Thanks in advance!
    Yours,
    Clint
    Hill
    CAD Systems Operation and Management
    Chemical Plant Process + Mechanical Design Focus Areas
    Cairo - no, not Illinois
    5,069
    Default Re: Win 7 & Lose XP 64-bit - Your Input
    Win7-64 or 32?
    one reality is that XP64 is still-born. essentially unloved and supported barely if at all by both hard and vendors. Win7 is new, lacks drivers for older devices, but seems much more stable and robust. I've only played with the 32 bit version, but if your hardware is up to XP64, you should like Win7-64 performance.
    2005-04
    Millville, NJ
    24
    Wink Re: Win 7 & Lose XP 64-bit - Your Input
    Possibly have you're IT Manager check out this Microsoft Technet article titled "Ten Things IT Professionals Should Know About Windows 7" which might shed some light on some of the positive aspects focused towards IT systems management and security Windows 7 has to offer.
    http://technet.microsoft.com/en-us/l.../dd350196.aspx
    Where I work we've been performing extensive testing on Windows 7 to prepare for company-wide use. We use many (100+) different engineering and design applications that needed to be tested for compatibility. We've also run into our share of problems with some applications that do not follow standard development practices and are always difficult to get working on new OS's. It's also expected since the vendors don't provide updates on a normal schedule. That's not to say we've not been able to overcome the issues with various work-arounds such as using different types of virtualization technology where necessary.
    Check out my releated post here:
    http://forums.augi.com/showthread.php?t=112828
    2005-04
    Millville, NJ
    24
    Post Re: Win 7 & Lose XP 64-bit - Your Input
    You could also share the information from the following site with your IT Manager:
    http://www.microsoft.com/everybodysb.../windows7.aspx
    At my company we're also in the middle of upgrading all of our Domain Controllers to Windows Server 2008 R2 to allow us to take full advantage of all the Windows 7 IT management features such as AppLocker, BitLocker, Direct Access, Branch Cache, etc.
  1. Replies: 5
    Last Post: 2007-05-08, 09:59 PM
  2. Input bearings when using dynamic input
    By rmk in forum AutoCAD General
    Last Post: 2006-03-13, 04:39 PM
  3. Lose changes?
    By patricks in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2005-10-21, 07:25 PM
  4. Lose changes?
  5. lose menus
    By ameen_abboud in forum ACA General
    Last Post: 2005-06-04, 01:00 AM
