Thread: Point/Data Management
    Active Member s_morgan_b's Avatar
    2007-01
    Cowtown
    90
    Default Point/Data Management
    Some months ago our office did the training for C3D 2010 and it seemed to go rather well.
    One of the questions that I haven't been able to get answered by the trainer was about point and data management.
    With this in mind, I had several related questions:
    1. What is the best form of data management?
    I can see that maintaining points "locally" for RPR and site plans as they don't need to go past that drawing. Larger projects, I need to ensure that I don't overlap point numbers going out to the field. My understanding is that I'd have to use the vault for this.
    2. What is the effect of having points in a XREF'ed file and how do they impact the local file you're working in?
    3. Can one set up C3D 2010 so that points are locked in place from the outset instead of having them, by default, being able to to moved and such?
    I'm still trying to figure out what some of the "right" questions to ask are.
    2006-12
    Loveland, CO
    734
    Default Re: Point/Data Management
    Look into using the survey database for this. Unfortunately, if you move a point in the database, you'll have to update the drawings. Laurie posted up a routine on the Customization discussion group (Autodesk not AUGI) that supposedly handles what you are looking for. I haven't tried it yet but I would bet his routine will work for you.
  1. Surface Data Management
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2014-06-16, 02:48 PM
  2. Inventor data management with Sharepoint
    By janlsing in forum Vault - General
    Last Post: 2008-10-08, 04:17 PM
  3. civil3d point management
    By uriimu in forum AutoCAD Civil 3D - General
    Last Post: 2008-04-18, 06:45 PM
  4. Point Management best practices
    By cadtag in forum AutoCAD Civil 3D - General
    Last Post: 2007-07-16, 03:59 PM
