jpeter
I was wondering if anyone has encountered the following issue. Within the last few months we've seen an increase in the number of users experiencing problems with STC. The one common denominator we’ve identified is that the issue appears to be limited to users working simultaneously in Revit 2010 (Sept 09 build) and AutoCAD Architecture 2008. Typically, a user will receive one of the following error messages in order:
1) File [central filename] is being accessed by someone else and is not available. Click Cancel to stop the current operation and try again later or wait for the file to become available.
2) The file you are attempting to synchronize with the central file is not compatible with the central file.
3) File not saved.
4) Alternately, if the user is working in AutoCAD or another Windows application, they will no longer be able to access network drives and receiving the following: [network drive] is not accessible. Insufficient system resources exist to complete the requested service.
Typically the user is able to resolve the issue by closing all applications and opening Revit after 5-10 mins and re-attempting a STC, on other occasions they have to perform a full system restart. No changes have been made to our networking environment recently and all users' systems have had their nic drivers updated to the latest release. Initially I applied the following registry key that addresses item #4 above, however, it appears to have no effect.
HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management\PagedPoolSize = 0xffffffff
Any suggestions or advice would be greatly appreciated.
