Thread: ArcSDE to CAD
    2009-04
    Default ArcSDE to CAD
    We have successfully linked AutoCAD Civil 3D 2010 to our SDE and have added several feature classes into DWG files. The process works great with feature classes of simple geometry types like points, polylines, and polygons. However, CAD crashes when you try to add Annotation Feature Classes. Everything looks like it is working and the Annotation Feature Classes shows up in the Map Workspace, but then CAD gets a 'Fatal Error'.
    Has anyone else encountered this issue?
    Has anyone successfully added Annotation Feature Classes to AutoCAD Civil 3D 2010 ?
    Member dmo1205342273's Avatar
    2005-06
    United States, Illinois
    45
    Default Re: ArcSDE to CAD
    Yeah I've gotten it to work but in 2011 C3D and AutoCAD Map from 2007-2011. How big is your data set? I work for a muncipality and use some county data sets which are pretty large (Parcels usually) so I'll add them with a query so they don't slow me down so much. Also aerial's are pretty labor intensive for CAD. Hope that helps.
  1. ArcSDE data not printing
    By mapnthem99.77065 in forum AutoCAD Map 3D - Data Connect (FDO)
    Last Post: 2010-09-13, 07:34 PM
  2. ArcSDE Connection
    By Mordechai.Yadegar in forum AutoCAD Map 3D - Data Connect (FDO)
    Last Post: 2009-08-14, 04:12 PM
  3. Map3D and ArcSDE
    By c_rado in forum AutoCAD Map 3D - General
    Last Post: 2007-01-25, 09:04 PM
  4. Autodesk Map 3D 2007/ArcSDE 9.1/SQL Server connectivity
    By mitzip in forum AutoCAD Map 3D - General
    Last Post: 2006-07-20, 05:29 PM
