Thread: "Lables and Tables" ribbon buttons disapeared?
    2009-12
    42
    Question "Lables and Tables" ribbon buttons disapeared?
    Under the "annotate" tab in the ribbon, my buttons for adding labels and tables has dissapeared. How do I get these buttons back in the ribbon?
    Earth
    9,804
    Default Re: "Lables and Tables" ribbon buttons disapeared?
    Known bug AFAIK.
    Switch workspaces to something else, then switch back to the Civil 3D workspace.
    They should come back....
    R.K. McSwain | CAD Panacea |
    2001-05
    Austin, TX USA
    2,201
    Check out the following thread
    http://forums.augi.com/showthread.php?t=105580
    2006-10
    2
    Here is a quick fix to get this back working correctly.
    1. Switch over to the Home Tab
    2. Close Civil 3D
    3. Reopen Civil 3D
    4. Switch back to the Annotate Tab
    Once reopened, the Panel will display correctly. Enjoy!
    The icons will disappear again if you close your Civil 3D with the Annotate Ribbon Tab active.
    2006-12
    Loveland, CO
    734
    ebolibol, that is a long fix, do as R.K. suggests for a quick fix. In fact, you don't even have to switch to a different workspace, you can just select your current workspace and it will reload.
  1. Replies: 20
    Last Post: 2015-05-16, 12:14 AM
  2. 2010 Quick Access buttons not "sticking"
    Last Post: 2009-04-14, 12:45 PM
  3. AutoCAD 2006 - Missing all the buttons on "Dimension" toolbar
    By jonathanschade in forum AutoCAD CUI Menus
    Last Post: 2007-03-23, 11:57 PM
  4. AutoCAD 2005 custom toolbar buttons show as "?"
    By jim.dozorec in forum AutoCAD Customization
    Last Post: 2006-07-18, 07:20 PM
  5. Can I program the "Back" and "Forward" mouse buttons for ADT3.3?
    By jhohman in forum AutoCAD Customization
    Last Post: 2004-12-29, 06:57 PM
