Thread: can't update existing dwg file
    2010-01
    2
    Unhappy can't update existing dwg file
    My name is Josh and for my schoolproject i have to make an electrical scheme therefor
    i'm using autocad electrical 2010 and an old scheme which i need to upgrade. Unfortunatly i have an problem with my dwg file:
    When i open it the file askes for VeSys.shx which is missing
    Then when te dwg file opens i can add components but i can't move or delete existing components.
    The original file is missing so i hope there is a way to solve this problem.
    I'm new with autocad electrical so i hope someone can help me
    I thank you for your time and pardon me for my bad english.
    Greetings,
    Josh
    2007-05
    14
    Default Re: can't update existing dwg file
    Josh,
    This is a linetype. Just do a google (or any search engine) search for "VeSys.shx". Once you find it save it in the AutoCAD directory "C:\Program Files\Autodesk\current Acade version\Fonts\" try to reopen your file.
  1. Update Existing Text Styles
    Last Post: 2013-11-14, 12:33 AM
  2. Update DimStyle and Keep all Existing Tolerances.
    By JNESKEY944614 in forum AutoLISP
    Last Post: 2013-04-17, 01:25 PM
  3. can't update existing dwg file
    By romy8111 in forum AutoCAD General
    Last Post: 2010-01-12, 10:25 AM
  4. How to write new menu file or update the existing menu in AutoCAD 2006
    By Partha Ghosh in forum CAD Management - General
    Last Post: 2007-09-30, 01:45 PM
  5. Replies: 1
    Last Post: 2007-06-06, 10:25 PM
