We've noticed an issue with the corridor section labels (specifically found in the link labels) where if the label is moved to a 'dragged state' then the drawing gets an error; and you cannot save the drawing. If the label is moved back to the original location, the drawing can be saved without error.
I've attached a .wmv file (with the extension renamed to zip) for you to see this in action. You will see the file being saved successfully, the label moved, the error on save, the label restored, and then the file saved successfully.
This only seems to occur when the corridor being sampled is xref'd in. With a couple hundred sections, we'd rather not keep these in our design model, as you know that hinders the performance substantially. If someone has a fix or an efficient workaround, I'd be much abliged.
Ok, so it's not wanting to upload the video (as a zip file), I'll try again later.
