Results 1 to 1 of 1
Thread: rs2010 consistency checks
    2010-01
    Default rs2010 consistency checks
    Hello,
    i upgraded a model from 2009 revit structure to 2010 revit structure, with 0 warnings.
    after running consistency check, i have hundreds of warnings.
    all relating to the steel beams "distance between analytical and physical models of structural element is beyond tolerance of 6".
    if i cut & past these beams back into the model, the warnings go away but
    I can't use cut & paste because I will lose all tags.
    is there a work around?
    Thanks in advance.
  1. Consistency
    Last Post: 2013-11-15, 02:37 PM
  2. Design Checks
    By pat.pennington in forum AutoCAD Civil 3D - Profiles
    Last Post: 2009-01-15, 03:59 PM
  3. Electrical and Interference Checks
    By jwongmep in forum Revit MEP - General
    Last Post: 2008-05-30, 09:10 PM
  4. Clearance for Interference Checks in Families
    By Tyveka in forum Revit Architecture - General
    Last Post: 2008-04-11, 06:53 PM
  5. Interference Checks with Pipes in 2007
    By melanie.santer in forum Civil 3D Tips & Tricks
    Last Post: 2006-08-03, 04:49 PM
