Thread: Cache problem
    2006-09
    2
    Default Cache problem
    Here's the issue: when outdated DWG and NWC files are deleted from a folder and we open the main NWF which has a myriad of files appended within - the file appears to still be within. That is, there's a remnant or some temporary location (outside of the project folder) which seems to be pulling this old data in. Obviously, we want to ensure that only the most recent files are aggregated within? Any ideas?
    Note: I've cleared the temporary file, C:\Users\<whatever>\AppData\Local\Temp, that had no effect.
    2008-08
    89
    Default Re: Cache problem
    Is it possible that outdated information is coming in through an xref attached to one of the DWGs?
  1. 2016: Elévation escalier caché
    By m.quijada659244 in forum Revit Architecture - Général
    Last Post: 2015-07-29, 02:47 PM
  2. ou se cache la famille
    By tmuche in forum Revit Architecture - Familles
    Last Post: 2010-01-25, 12:46 PM
  3. élément caché
    By tmuche in forum Revit Architecture - Général
    Last Post: 2008-11-04, 11:51 AM
  4. Surface caché
    By yusukens82 in forum Revit Architecture - Général
    Last Post: 2008-09-14, 07:12 AM
  5. Le libellé caché...
    By 6b.architecture in forum Revit Architecture - Général
    Last Post: 2008-02-07, 07:43 PM
