Thread: Obtain layer name from insertion point
    2001-01
    257
    Default Obtain layer name from insertion point
    Hi All
    I have a routine that I use to insert arrows blocks at the end of selected lines or objects. The routine automatically sets the osnap to endpoint upon insertion. What I would like the routine do is determine the layer of object from the insertion point. This way I can change the layer of the arrow block after insertion. Thanks in advance.
    Manuel A. Ayala
    2009-06
    16
    Default Re: Obtain layer name from insertion point
    Suppose the insertion point is set to pt, have you tried:
    (cdr (assoc 8 (entget (car (nentselp pt)))))
    2001-01
    257
    Steve.K
    That seems to have done the job. Many thanks.
    Manuel
    2009-06
    16
    Great! You're welcome Manuel.
  1. Replies: 21
    Last Post: 2012-10-10, 02:38 PM
  2. Obtain Section View Band Information from Point Codes
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2008-05-22, 10:05 PM
  3. RL insertion point
    By kristreagus in forum Dynamic Blocks - Technical
    Last Post: 2007-11-08, 03:33 AM
  4. Placing insertion point at mid-point of flange on a steel section
    By Spenner in forum Dynamic Blocks - Technical
    Last Post: 2007-06-18, 01:53 PM
  5. Replies: 3
    Last Post: 2007-04-20, 12:33 AM
