Thread: Publishing sends all other windows to background
    2010-01
    2
    Cool Publishing sends all other windows to background
    Publishing in AutoCAD Electrical 2010 sends all of my other open windows to the background each time a drawing is activated. I cannot work in any other windows because my cursor is removed and the foreground window is no longer the "current" window. This is very frustrating when publishing 100's of drawings. It doesn't matter if AutoCAD is minimized or maximized. This happens regardless of the background plot processing options.
    This was not an issue for me in previous versions of AutoCAD.
    I haven not found a fix by searching the forums. Any advice will be appreciated.
    Todd
    2000-01
    Seattle WA USA
    5,859
    Default Re: Publishing sends all other windows to background
    I haven't seen this issue, but I'm not using Electrical. However, are you sure that a mouse driver setting isn't the real issue?
    R. Robert Bell
    Design Technology Manager
    Stantec
  1. Joining Channels to Angles sends components skewing at odd angles. (REVIT Struct 2012)
    By Melissa.Stewart1980 in forum Revit Structure - General
    Last Post: 2012-05-25, 05:56 PM
  2. Plotting through sheet set-sends 3 drawings and crashes
    By okillham in forum AutoCAD Plotting
    Last Post: 2006-04-13, 02:38 PM
  3. Windows Thumbnails - White Background
    By robertb.65723 in forum AutoCAD General
    Last Post: 2005-11-03, 07:36 AM
