Thread: Beam system Indicator
    2007-09
    Raleigh NC
    755
    Default Beam system Indicator
    the indicator that shows the spacing and direction is not showing up. the systems still responds when I move columns, but I can't select it for editing. Any ideas why it's not showing up? Thanks.
    Active Member TheViking's Avatar
    2005-03
    Lexington, MA
    88
    Default Re: Beam system Indicator
    The actual system can be defined lower then where the beams should up. This is something that happens quite often with 3D Beam Systems. Try selecting in a 3D view to see which level the system is defined on.
  1. The beam system tool should allow users to specify the location of the first beam.
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2013-06-08, 03:32 PM
  2. Editing Beam Extensions or slope in a Beam System?
    By thredge in forum Revit Architecture - General
    Last Post: 2009-03-24, 04:23 PM
  3. Spot Elevation setting? Top Indicator, Bottom Indicator?
    By scowsert in forum Revit Architecture - General
    Last Post: 2008-10-22, 12:55 PM
  4. More Control of Coordinate System Indicator
    Last Post: 2007-01-19, 12:06 PM
  5. Beam start & end indicator
    By kornackiph in forum Revit Structure - Wish List
    Last Post: 2006-09-03, 04:10 AM
