Thread: How to: Import Mass family... into another mass family?
    2008-07
    55
    Default How to: Import Mass family... into another mass family?
    All-
    I have one conceptual mass, with another family (Mass) referenced in. I now need to combine the contents of these two files. Is there a way to import the actual geometry of the second mass... I don't need to link or reference it, I just need to merge the two files.
    A copy-link-in-place command would work.
    Help? Thanks.
    2008-07
    55
    Default Re: How to: Import Mass family... into another mass family?
    Further information, with fingers crossed that it sparks some sort of reply:
    The main family contains a mass-void that will need to clip ALL geometry. This includes all geometry within the family (currently clipped) as well as the referenced mass-object (not currently clipped). If there is a way for a mass-void to clip imported/referenced geometry, that would do the trip. Can it?
    (OPTION 1)
    I would simply copy-paste material in from the referenced file, but the actual geometry does not 'exist'... the referenced file contains only a single line and several parameters which result in geometry. As such, I think I would need to select the geometry as it appears when referenced and use some sort of 'copy-in-place', 'make live' or similar command.
    (OPTION 2)
    I'm just not sure if either of these are possible. Thx.
  1. Mass floors in conceptual mass family environment?
    By twaldock in forum Revit Architecture - General
    Last Post: 2010-11-15, 11:44 PM
  2. Mass family - levels
    By mmiles in forum Revit Architecture - General
    Last Post: 2009-08-05, 10:53 AM
  3. Mass Family - Mass Schedule - Missing Parameters
    By mmcdonald in forum Revit Architecture - Families
    Last Post: 2009-02-26, 06:19 PM
  4. Mass gable family
    By bob.86982 in forum Revit Architecture - Families
    Last Post: 2007-08-12, 04:03 PM
  5. Nested family using mass
    By ljupadhyay in forum Revit Architecture - Families
    Last Post: 2007-04-12, 02:23 AM
