Thread: Standard AutoCAD templates
    2005-01
    119
    Default Standard AutoCAD templates
    I am primarily a 2D drafter. I would like to do some 3d tutorials. So I figured I would start by using one of AutoCADs out of the box .dwt's but I can't find them? I have even done a windows search on my computer for dwt. files but none of them show up.
    Did 2010 come with standard template files
    If not, Is there somewhere I can download them
    appreciated
    Mike
    0,0,0 The Origin
    8,570
    Default Re: Standard AutoCAD templates
    They should be under Program Files in \UserDataCache\Templates.
    \UserDataCache is set to hidden by default.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,196
    OOTB template files are located in the users Local Settings directory branch
    C:\Documents and Settings\username\Local Settings\Application Data\Autodesk\AutoCAD 2010\R18.0\enu\Template
    Replace username above with your username on your computer.
    If they are not there on your system, you should be able access them from the UserDataCache directory branch found here
    C:\Program Files\AutoCAD 2010\UserDataCache\Template
    2005-01
    119
    That did it.
    Thanks
    Mike
  1. AutoCAD 2016 templates
    By scott602141 in forum AutoCAD General
    Last Post: 2015-03-04, 05:01 PM
  2. Standard templates
    By archdraught in forum ACA General
    Last Post: 2008-03-12, 08:13 PM
  3. Replies: 4
    Last Post: 2006-09-21, 02:56 PM
  4. Creating Standard View Templates...are they worth it?
    By cparsons in forum Revit Architecture - General
    Last Post: 2006-02-24, 04:06 PM
  5. Missing Project Standard Templates in ADT 2006
    By dbroughton in forum ACA General
    Last Post: 2005-04-30, 06:45 PM
