Thread: View Templates and Design Options
    2007-01
    466
    Default View Templates and Design Options
    I've created a view template, whose sole setting is to change the Design options visible in a given view.
    When I apply that design option to a number of views at once, it doesn't seem to work properly. Sometimes, the elements in that design option become invisible. Sometimes, under Visibility / Graphics, that a given design option seems to be set correctly, but the image on the screen represents the other design option.
    Does anyone have any experience with this? Any way to fix this?
    Thanks in advance.
    Bryan
    2008-04
    86
    Default Re: View Templates and Design Options
    I am experiencing this in Revit 2012. It does not make sense.
    2007-05
    SF CA USA
    314
    I have experienced this when making multiple view setting changes, or doing a lot of toggling back and forth. I believe its a graphics regeneration issue, but haven't nailed it down to that completely. I do NOT experience the issue if I am not flipping options back and forth, or pushing out a change to multiple views. When you see the issue, try closing Revit, reopening and seeing if the issue repeats.
  1. 2013: Design Options in a 3D View and Annotation
    By ch0mpion in forum Revit MEP - General
    Last Post: 2013-02-08, 04:21 PM
  2. 2012: View templates that set options in the "extents" header
    By Joshua Kohl in forum Revit Architecture - General
    Last Post: 2011-11-07, 03:58 PM
  3. View Templates with additional options....
    By AJGKennedy in forum Revit Architecture - General
    Last Post: 2008-07-31, 09:06 PM
  4. Design Options - View Properties
    By bmarler in forum Revit Structure - General
    Last Post: 2005-10-13, 02:14 AM
  5. View only design options
    By adegnan in forum Revit Architecture - Wish List
    Last Post: 2004-09-14, 12:01 PM
