Results 1 to 9 of 9
Thread: Acad 2010 (menucmd...) problems
    2001-11
    11
    Default Acad 2010 (menucmd...) problems
    Until recently, I have been running AutoCAD 2009, but upgraded to 2010 earlier this month. Probably since AutoCAD 2002, I have used a Lisp program called by keystrokes defined in a "acad.pgp" file, to pull down certain customized menus from the menu bar. At startup the custom menu files are loaded and the Lisp routine is used to pull down or "Pop" (display) the menu. The problem I am experiencing is that the Lisp program no longer pulls down any menu. The menus are succesfully loaded as can be seen by the title on the menu bar and also, they can be manually pulled down by selecting the title.
    In short, the Lisp code to pull down the menu, (menucmd "p13=*"), no longer functions after installing AutoCAD 2010. However, I still have AutoCAD 2009 installed on the same computer and it works well. Both versions of AutoCAD use the exact same customization files: Acaddoc.lsp, ".mnl", and ".lsp", etc. files. Also, the new compiled menu files, (AutoCAD 2010: .cuix - AutoCAD 2009: .cui, mnr, etc.) are created from the same original ".mnu" file.
    I have tried simply entering the (menucmd "pn=*") at the command prompt, with no success, except when I use n=0, in the Lisp command. Only then, a context menu appears, which is not a pull-down. No other menu slot number works. However, all slot numbers (1-16) work as expected when I launch AutoCAD 2009.
    I am aware AutoCAD has changed the compiled menu format AGAIN!!!!!!! in 2010 and I wonder if something is not working correctly in this new format, or if there is a new system variable that I am not aware of, that freezes the menus. (Can't imagine why.) The circumstances seem to point to a "bug" in the new menu structure.
    Any help would be appreciated.
    2004-08
    Iron Station, NC
    3,197
    Default Re: Acad 2010 (menucmd...) problems
    I dont know that I would consider it a bug, but Autodesk is attempting to eliminate menus all together, this could account for the change in how the command functions. Can you assign an alt+ key to get them to pop down, like you used to be able to press Alt+F and get the file menu to drop down?
    Christopher T. Cowgill, P.E.
    Autodesk Expert Elite
    AEC Collection Civil 3D 2020
    Windows 10
    2015-11
    Jo'burg SA
    4,512
    I wonder if there's a way of using WScript's SendKeys method. I've tried linking to the ActiveX object of WScript.Shell, but it doesn't appear to have the SendKeys function in AutoLisp as it does with other programing languages. There's only an Exec method.
    If this was possible you could send "%F" to emulate pressing Alt+F.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,659
    This appears to be a bug. The (menucmd "p13=*") code works in Civil 3D 2010. I was not successful with AutoCAD 2010.
    2015-11
    Jo'burg SA
    4,512
    Is it maybe something to-do with the ribbon? Have you got the menu bar turned on / classic interface Workspace?
    2002-01
    jUSt Here (a lot)
    8,659
    Quote Originally Posted by irneb View Post
    I just tested this again with no problems. The quick (menucmd "p13=*") function worked. Yesterday's test, I had AutoCAD 2010 open along side Civil 3D 2010. I have no idea what happened yesterday.
    2015-11
    Jo'burg SA
    4,512
    Maybe the 2 versions screw with each other's memory spaces. Not impossible since they share quite a few libraries.
    100 Club hofcad's Avatar
    2005-09
    111
    You mean:
    (defun SendKeys (KEYS / WSCRIPT)
      (vl-load-com)
      (if (setq WSCRIPT (vlax-create-object "WScript.Shell"))
        (progn
           (vlax-invoke-method WSCRIPT 'sendkeys KEYS)
           (vlax-release-object WSCRIPT)
      (princ)
    (defun c:%F() (SendKeys "%F"));File Menu
    (defun c:%E() (SendKeys "%E"));Edit Menu
    (defun c:%V() (SendKeys "%V"));View Menu
    Regards, HofCAD.
    2015-11
    Jo'burg SA
    4,512
    Thanks, that's what I tried ... must have mistyped somewhere
    Works great!
  1. ACAD 2008 vba compatible with acad 2010?
    By Ammon in forum VBA/COM Interop
    Last Post: 2011-01-12, 10:27 PM
  2. Serious problems between Navisworks 2010 & Revit 2010
    By dramage.190144 in forum NavisWorks - General
    Last Post: 2009-09-15, 03:11 AM
  3. Problems with exporting from Revit 2010 to NW 2010
    By anthony.foster-davis in forum NavisWorks - General
    Last Post: 2009-06-12, 04:39 PM
  4. Problems with ACAD.LIN
    By Chris.Partin in forum AutoCAD Customization
    Last Post: 2005-04-22, 02:11 PM
