Thread: Batch family update tool...
    Revit Guru gregcashen's Avatar
    2003-05
    Emeryville, CA
    1,352
    Default
    Anyone know where I can find that thing?
    2003-05
    5,153
    Default Re: Batch family update tool...
    Can't recall where this came from, and I haven't used it myself .... so caveat emptor.
    Instructions:-
    Place these 2 files ( from the zip ) in the main directory where
    your revit families are. Then double click on the upgrade_rfa.bat file.
    Wait for it to scan all your files to be upgraded. This could take a little time if you have a major amount of families to upgrade and should close out automatically when it is done searching. This will create a "families.txt" file in that directory then. Then leave your browser window open and make sure you can see your Revit icon on your desktop and drag theUpgrade_rfa.txt file onto that icon. Revit will automatically start and then open and close all the family files in the families.txt file until they are all upgraded.
    Now this can hog your computer system resources if you have a lot of them to do, but works.
    good luck.
    2003-05
    Emeryville, CA
    1,352
    Thanks! I had just found this again on RUGI..but thanks for the response.
  1. 2014: no thumbnails for 2014 content after batch update
    By geistwolke in forum Revit Architecture - Families
    Last Post: 2014-07-14, 07:24 PM
  2. Family Update Batch File
    By Chris DiSunno in forum Revit Architecture - General
    Last Post: 2008-04-25, 07:15 PM
  3. RA2008/N - Batch Create Family Parameters From Nested Family - O
    By atbergma in forum Revit Architecture - Wish List
    Last Post: 2007-07-11, 06:33 AM
  4. Batch Replace Blocks and Update With Old Attribute Values
    By brad.moon126662 in forum AutoLISP
    Last Post: 2007-07-03, 02:52 PM
  5. batch update of attributes
    By wrogers in forum AutoCAD LT - General
    Last Post: 2005-09-13, 07:26 AM
