Although the DWG TrueView 2010 interface does not provide a way to turn off the ACA/MEP solution tips (those yellow triangle exclaimation icons) it is possible to turn them off.
Merge the attached file into the registry when DWG TrueView 2010 is not running and the tips will be turned off the next time the application is started.
Rename the TXT extension on the attached file to REG in order to merge it into your registry.
