Thread: Same detail - multiple sheets
    2010-01
    10
    Default Same detail - multiple sheets
    There is an iso-detail view I want to use on six separate sheets with the same title. Revit is making me copy the view 5X, and the titles then read "(copy 2) of Detail View". I can live with copying the view six times, but I really need the titles to all read simply "Detail View". Any ideas how I can work around this?
    Andrew
    2002-06
    North Central CT
    1,108
    Default Re: Same detail - multiple sheets
    Select a view in the project browser, right-click and select ELEMENT PROPERTIES. In the IDENTITY DATA section there is a field for TITLE ON SHEET. Change that to whatever you want; in your case you would change it to say Detail View. This applies to any view (floor, detail, callout, etc...)
    Matt
    2009-01
    345
    Matt is absolutely right. They won't let you have views of the same name but they will let you have views with the same "name on sheet". Additionally you may want to look into dependent views for cases like this so that when changes are made to the detail it will be reflected on all 6 copies.
    8
    You can create a new legend and paste the content of the drafting view into the legend, then place it on as many sheets as you want.
    HTH,
    John
  1. Single Detail on multiple sheets
    By katysue in forum Revit - Platform
    Last Post: 2008-09-15, 10:33 PM
  2. Re-associate detail view labels with re-imported detail sheets
    By pgastelum77763 in forum AutoCAD Sheet Set Manager
    Last Post: 2007-01-12, 06:18 PM
  3. Tip: Aligning Multiple VIews on Multiple Sheets
    By d.stairmand in forum Revit Architecture - Tips & Tricks
    Last Post: 2005-09-08, 02:19 AM
  4. Duplicate sheets & views on multiple sheets
    By Chad Smith in forum Revit Architecture - Wish List
    Last Post: 2005-03-30, 04:04 PM
  5. Detail Book vs. Detail Sheets
    By Dimitri Harvalias in forum Revit - In Practice
    Last Post: 2005-02-12, 11:14 PM
