Thread: Migrate utility
    Active Member modulor's Avatar
    2004-06
    Los Angeles
    93
    Angry Migrate utility
    Migrating settings on installation of AC2010 seemed like a good idea at the time, but it has turned out to be more trouble than it's worth. Most notable problems are with publishing to PDF:
    2007 -> 2010 - dwgtopdf works great. acrobat pro 8 doesn't work. Adobe pdfmaker apparently not compatible with 2010. Weird missing partial menus, http://forums.augi.com/showthread.php?t=102193
    And oddly, annotation tools are removed from the Modify menu.
    2008 -> 2010 - Neither dwgtopdf, nor dwf export works (null pointer error?), but Acrobat works OK.
    Anyway, is there an easy way to UNmigrate settings?
    2004-08
    Iron Station, NC
    3,198
    Default Re: Migrate utility
    repair installation, or reinstall
  1. Replies: 0
    Last Post: 2015-08-07, 05:37 PM
  2. 2011: migrate custom workspace to '11?
    By Maverick91 in forum AutoCAD General
    Last Post: 2010-05-24, 07:44 PM
  3. Migrate Settings
    By KellyR in forum AutoCAD Customization
    Last Post: 2006-09-20, 03:05 PM
  4. Migrate Custom Settings
    By Brian Myers in forum ACA General
    Last Post: 2006-05-02, 01:32 AM
  5. migrate from AutoCAD
    By iffans in forum Revit Architecture - General
    Last Post: 2005-12-12, 07:53 AM
