Thread: Creating a Sail Shape in the Conceptual Mass tool
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Default Creating a Sail Shape in the Conceptual Mass tool
    I'm having difficulty making a smooth sail form. Revit keeps triangulating the pieces. Please see attached and let me know if you know how to make it smooth.
    Scott D. Brown, AIA
    BECK
    Certifiable AUGI Addict
    2004-05
    St. Louis, Missouri
    3,135
    Cool Re: Creating a Sail Shape in the Conceptual Mass tool
    Scott,
    I suspect that the shape is a NURBS ( Non-uniform Rational B-Spline )
    complex curve and Revit can not create it without triangulation. ( nor can 3dsMax,
    as I understand it. )
    I think Maya can handle this NURBS surface, and perhaps Rhino.
    If you render it, do you still see any triangulation? Or is it just that in un-rendered
    views you do not want to see the lines of the triangulation?
    cheers...
    2003-05
    Coast to Coast
    4,440
    Default Re: Creating a Sail Shape in the Conceptual Mass tool
    I don't need it rendered at this point. I suspect there would be a slight edge but not too bad.
    Scott D. Brown, AIA
    BECK
    AUGI Addict jeffh's Avatar
    2002-09
    Manchester, NH
    1,087
    I just did a test render on a sample one and it does show the edge. I have done this kind of shape with a series of parallel splines and then lofted them. Using a spline along the 3 edges will result in the triangulation you are seeing. Depending on how differnt the "z" values of the corners of the sail are these edges may be more pronounced. If the difference is not great then the rendered version might be acceptable.
  1. Replies: 3
    Last Post: 2013-09-11, 12:29 AM
  2. conceptual mass (help me!)
    By esi_badghelegh in forum Revit - Conceptual Design Tools
    Last Post: 2011-12-30, 04:50 PM
  3. Using Conceptual Mass in other Families
    By Dario in forum Revit Architecture - Families
    Last Post: 2010-11-16, 02:31 PM
  4. Mass floors in conceptual mass family environment?
    By twaldock in forum Revit Architecture - General
    Last Post: 2010-11-15, 11:44 PM
  5. creating a parametric box as conceptual mass
    By echte in forum Revit Architecture - Families
    Last Post: 2009-07-14, 12:13 PM
