Just wanted to post what my students are doing for a final semester project.
Comments Welcome
Comments Welcome
Try getting some good bitmaps for your materials. The brick texture is too pink and the grass looks too flat. Stay away from the basic Accurender materials, and your renderings will look much better.
Yes thanks,
I really just went with the default stuff to save time. The rendering is only meant to be a sample for the students to by.
I did play a bit with it in photoshop to get that hand done look.
Building seems to float on Air....(YOu can make out from the shadow) Add a bit of foundation or extend the external wall at the base so as to merge in to the toposurface.
Xavier,
Thanks for the comments, I didn't even realize it was floating. I saw the shadow but I thought it was a reveal between the brick and foundation. I adjusted the model and the terrain and played with it in Photoshop again. Its addicting.
